enable ip-security anomaly-protection icmp
enable ip-security anomaly-protection icmp {slot [ slot | all ]}
Description
Enables ICMP size and fragment checking.
Syntax Description
slot Specifies the slot to be used.
all Specifies all IP addresses, or all IP addresses in a particular state.
Default
The default is disabled.
Usage Guidelines
This command enables ICMP size and fragment checking. This checking takes effect for both IPv4 and IPv6 TCP packets. When enabled, the switch drops ICMP packets if one of following condition is true:
  • Fragmented ICMP packets.
  • IPv4 ICMP pings packets with payload size greater than the maximum IPv4 ICMP-allowed size. (The maximum allowed size is configurable.)
  • IPv6 ICMP ping packets with payload size > the maximum IPv6 ICMP-allowed size. (The maximum allowed size is configurable.)
This command was first available in ExtremeXOS 12.0.
Platform Availability
